Draft image: Roof-to-Roof Flashing
I’ve attached a new draft image to preview, before finalizing. I’d like to hear any valuable feedback from the forum. Thanks for your help!
Metal flashing would go over the lower roof surface. Flashing is always installed “shingle fashion” ….under then over.
Personally, I would eliminate the verbiage “embedded” from the ‘Gravel built-up roofing’ statement!
There are multiple types of “Gravel surfaced” roofing systems, and although similar in design, they are not interchangeable.
Gravel Ballasted Roofs.
True. And I do not recall ever inspecting a BUR on a residential property, though I am sure they do exist, just not in my area. Generally, it is a rolled material of some type.
I think I have only inspected about three (as designed and built) Residential homes with BUR in the last ten years. Not commonplace at all, (excepting where old commercial buildings have been converted or built mixed use for partial residential occupancy).
Looks good from here.
Metal flashing is fastened/nailed high.
The BUR membrane continues up the slope for 3’ feet. Snow/ice/water will tend to pool at the transition.
I tried a different angle for a better view. Hit refresh for the updated image.
Thank you!
I am focused on this detail. Where does this flashing terminate? Is it tucked under the BUR? Or as shown, just a strip of metal?
Me too.
Think about exactly what is stated in the text box. Seems to be self-explanatory to me. If the membrane extends 12 inches up the roof slope, how would one “tuck it under” the BUR?
That being said…
(No offence to Staff) that is tasked with these projects, but they really should educate themselves on the subject matter prior to creating these images. This is a common problem with most images created, and hoping Members will bother to point out the mistakes/concerns observed.
Ironically, these images are intended primarily for new inspector use.
Updated image, hit refresh.
Thank you!
