Draft image: Townhouse Inspection Overview
I’ve attached a new draft image to preview, before finalizing. I’d like to hear any valuable feedback from the forum. Thanks for your help!
Typically, a garage…
…doesn’t have a crawlspace under it.
It would have a slab on grade.
Not always. I occasionally see crawls, but typically basements.
It would be nice for a Image of the Center/Middle Unit(s), to include the fire-blocking in the attic and (sometimes) the basement(s)!
Are you saying you have seen a basement or crawlspace under a garage?
A cutaway of the attic showing the “firewall” between units would helpful.
What is the goal? Most houses are better represented by a 2 dimensional floor plan.
Drawing is a little cramped. Standard dimension is 25 feet by 50 feet.
Absolutely, and even more common, is a Media Room / Theater below the garage!!
Concrete vault media room crawlspaces under a townhouse garage must be a Minnesotan thing since you come across them so often.
When you experience annual 4-5 month Winters, with a couple of them being sub-zero down to -30f… plus the wind chill… let’s see how important your Man Cave becomes!!
14 is not a gutter; it is a downspout.
12 forced air furnace/air handler
A few arrows pointing at the components would add clarity. I see no sidewall cladding, sheathing, WRB, or fenestration details, as illustrated in the attic and roof.
I would identify the crawlspace, identify the crawlspace access panel, and identify the crawlspace vents as such.
I’m not sure the point.
Townhomes come in many different layouts.
We have a lot of tri-level townhomes.
Some have partial crawls, most don’t.
But we also have one story townhomes for seniors.
And all sorts of variations in between.
Slab on grade common here. 50 ft. deep, 25 ft. wide. Extra credit to any one who can correctly identify the white square on each rear wall.
They look like egress window wells, eh?
Give this man a Kewpie doll!
Thanks, Bob.
It’ll be my first Kewpie doll.. Wooo, Whooo! :rofl:
Come on man, you’re old enough to have visited carnivals where that was the first thing you won!
For some strange reason, despite a range of glittery prizes, that was the only thing you ever won!
I run into a basement under a garage once or twice a year.
Including a firewall(s) in the description may be helpful.
I went to very few carnivals and did win a stuffed animal once but never a kewpie doll.
You are my first. :rofl:
If you say that you have inspected row house townhome garages above a basement, then who am I to argue?
Should Zac add additional support for the garage floor to his image or is the stem wall and pier sufficient?
