I’ve attached a new draft image to preview, before finalizing. I’d like to hear any valuable feedback from the forum. Thanks for your help!
@zupright - basic thoughts:
It is a bladder in the tank - not an air cushion
Make a note saying the expansion tank should be strapped
Make a note saying that "once a faucet is opened on the hot side, the bladder returns to normal and pressure is restored
It would also not hurt to say that the expansion tank should be set to match the inlet water supply pressure from the utility…
Heading in the right direction though
Deleted post
And many jurisdictions, the expansion tank cannot be supported by piping material.
Looks really good however the verbiage makes it seem that you can either have an expansion tank or TPR valve when in reality , you need both with a closed system.
Image has been updated, hit refresh.
Thank you!
