Drainage in Florida
While conducting an exterior inspection i found that there is no gutters around the property, which led me to acknowledge rarely any homes in the area had gutters installed. What determines whether a house gutter system is optional?
Not required in GA. I think a requirement for gutters would be an exception, an not the rule.
Basically the two determinates are local rules (around here gutters are required) and common sense.
A large portion of GA has clay soil and gutters are surely needed. Georgia’s central, south and coastal areas have sandy soil and they are gutters not installed as consistently.
They are a must have on my home, and I hate them, lol!
The previous replies are good. Personally & professionally, I can’t stand gutters & believe that good design & the conditions at hand, negate the need for gutters. But, sometimes you have got to have them for some conditions, perhaps where everything was not thought out thoroughly in advance. What else is new…Be warry of how they are installed (with straps (preferred) or spikes), the material, how or what they drain into, is the water still being carried away from the foundation, etc.
Morning, Terry. Hope to find you well.
I am not from Florida. But to my basic recollection on the subject, through the years of reading the message board, gutters are not always mandatory. Their necessity is dependant upon factors like local climate, soil type/s, landscape direction and existing municipal drainage systems for that area. That rule resides within in your local jurisdiction.
A: Read members posts. B: Await for others to chime in.
Remember, gutter troughs and downspouts aren’t the only sole option to direct rainwater away from a home or structure. >< 12 inch wide sloping, high to low trench, with perforated pipes or drainage tiles, referred to as a french drain water management system, buried in the soil leading to a drywell or diverted near a municipal sidewalk or municipal soil/groundwater management collection interception trench.
That’s my wag.
Point 1: If the home is built on a mountain of sand, gutters are optional.
Point 2: Florida is built on a mountain of sand.
Point 3: In the rare part of Florida(parts of the panhandle, I’m looking at you), that isn’t built on a mountain of Sand, gutters are still optional.
You will probably only find gutters on about 30% of the homes you inspect. I only call it out when I see significant washout or exposed foundations as a result, or I see drainage issues that could benefit from gutters.
