The crack shown in the middle left of the driveway picture has about a 1/4in vertical shift. The soil under the driveway had been eroded. The area of the wash out and around the sprinkler head is depressed and does not allow for proper drainage. This spot does slope away from the driveway….
Do I address possible causes for the erosion? Sprinkler head location would seem a likely source. However it does popup and not spray directly into the side of the washed out area of the driveway. Hard to see but in the upper right corner of the picture is a landscaping bed. The elevation of this planter bed is such that water is trapped and forced to percolate into the ground and could be contributing if not causing the erosion. I also know these houses well, and prior to the roof and gutters being replaced about 2 years ago, there was a down spout that used to dump water onto the driveway and walkway in the upper right of pic. That volume of water could easily have caused the erosion.
I am not sure how to call this out? Grading in need of correction… but what about the concrete of the driveway itself. It is not crumbling of the like and is sdoing its job. But certaily will need repair or replacement at somepoint and the erosion shortens that time
That is a pretty good narrative. It needs nothing more and could be shorter. Add a recommendation for a qualified person to repair/correct this issue and you are done.
ndegaris
(Neil DeGaris, CMI® KY License # 102167)
3
Just recommend sealing all cracks!
ndegaris
4
As do all things.
Your report is for and only the day of inspection. Don’t try to predict the future of what could or could not happen.
On this particular defect, no need to get excited. Just state your observations and move on. People are pretty smart and will not need much embellishment.
The driveway had some cracking and settlement. Poor ground drainage or slope along the driveway may contribute to the problem.
Recommend crack repair/treatment and site drainage correction by a qualified contractor.
ndegaris
8
No. Report what you find and the consequences of any defects or deficiencies. It is outside the scope of an inspection to determine the cause of defects and deficiencies.
This could be a narrative I use when I did reports.
Report what you observed.
During an inspection: I would take my 24" or 4" spirit level and placed it perpendicular dead center over the crack.
By placing a weight on one end of the level the other end would be raised and the slab settles or there would be a gap in the center below the level.
Again: Report what you observed.
Lot/Grounds.
Lot. Organic mulch or cedar bark mulch in planting beds at the front of the house. Impervious Soil should be sloped away from the foundation.
Deficiency: Soil loss on the right side of the poured concrete driveway. Most notably at the sprinkler head.
Poured concrete curb runs parallel in front of planting beds at the front of the house. The curb may act as a dam prohibiting rain water from naturally flowing downstream.
Driveway. Poured concrete.
Defect: A crack runs almost the competed width of the driveway.The poured concrete slab appears to have differential settlement.
Insufficient control joints.
The poured concrete driveway appears higher than the bottom of the garage door. Hypotheses. Driveway below the current poured concrete drive. Water can collect and be driven under the garage door.
All sounds good except the control joints part. This driveway and other in the complex all have cut control joints that leave about 100sf sections of concrete between
I agree. It is hard to see in the pic but there is a control joint about 18 inches above the crack and the next is just out of frame in the pic. Also a long control joint runs down the center of the driveway, which though is in the pic is very hard to see
