Dual pane windows
Originally Posted By: jane molina
Hi guys
Are dual pane windows , windows with the thickness of two windows.
say one on the outside and one on the inside. I want to make sure that
that is what is meant by dual pane windows.I believe a single pane
window would be like a stationary windo up high in a home and not egress.
Is this correct?
Thanks Jane
Originally Posted By: jpeck
Jane,
Dual pane window "double glazed" have two panes in each sash with a sealed insulating space between them. Some are more advanced than that, but that is your basic dual pane window.
You are thinking of single hung versus double hung.
Single hung is where the upper sash is fixed and the lower sash is movable.
Double hung is where both sashes are movable.
Jerry Peck
South Florida
Thanks Jerry , I had the right idea on the dual pane , i appreciate it.
