Dual purpose boiler question
I probably should know this, but I need some info on how a dual purpose boiler works.
The system ran the in-floor heat and also provided the hot water for the home use. I was a bit confused trying to figure out how it keeps the water temp for home use at 105, but heats higher for the in-floor heat. I saw no temp. control at the tank (or energy source for that matter). Any literature would be helpful for the next time I run into one.
Originally Posted By: wcottrell
make and model number would be helpful
Does it really matter?..just looking for some general information on how these “type” of systems function.
Kevin you might try this for more info
Bill
Originally Posted By: Lee Hammerstein
These systems use a mixing valve that brings the water to a lower tempature for the in-floor heating. Hot water from the boiler is mixed with the return water from the in-floor loop and cooled to the desired tempature.
So, I am assuming that you have to set the mixing valve to adjust the temp. of the hot water? i
Originally Posted By: bgentry
bingo.
Bradley S. Gentry
Superior Home Inspection, LLC
Harrisonburg, Charlottesville, &
Elkton, VA
www.superiorllc.net
