Hi all,
Boulder County currently has an opening for an Electrical Combination Building Inspector. If you or anyone you know are qualified and interested please apply at -
Jobs - Boulder County
Here are the details:
Salary
$59,964.00 - $86,328.00 Annually
Location
Boulder County, CO
Job Type
Full-time
Department
Community Planning and Permitting
Closing
2/28/2022 11:59 PM Mountain
Description
The Boulder County Community Planning & Permitting Department is seeking an Electrical Combination Building Inspector. This position will perform technical inspection duties, to include electrical, plumbing, mechanical and structural framing in the enforcement of International building codes and Boulder County amendments. Inspector will also perform inspections for zoning, planning and wildfire requirements
This is a full-time, benefitted position. The work schedule is Monday - Thursday, 7:00am - 5:30pm, although there is an option for flexibility with the schedule . This position is primarily a remote position. County vehicle will be provided. Under FLSA guidelines, this position is non- exempt (eligible for overtime) .
Boulder County requires its employees to reside in the state of Colorado as of the first day of work.
As of December 1, 2021, Boulder County requires all employees to be fully vaccinated against COVID-19 or request an approved accommodation within ten days of accepting an offer of employment. A person is considered fully vaccinated two weeks after completion of a two-dose mRNA series or one dose of Johnson and Johnson vaccine.
Hiring Salary Range: $59,964.00 - $73,000.00 Annually
Classification Salary Range: $59,964.00 - $86,328.00 Annually
Tentative Hiring Timeline:
- Phone Screening: March 7th
- First Round Interviews: March 14th
- Second Round Interviews: March 21st
Examples of Duties
Performs inspections on residential and commercial buildings being constructed, repaired or remodeled for compliance with building, electrical, plumbing and mechanical codes, and Boulder County amendments.
Examines and reviews building construction plans to ensure compliance with Boulder County approved plans and applicable codes and ordinances, or detect any discrepancy between plans and finished building
Performs inspections for zoning, planning and wildfire requirements
Provides information to contractors, homeowners, engineers and other interested parties on building codes and amendments.
Maintains familiarity with existing, revised and new applicable building codes and amendments
May make recommendations to proper officials regarding appropriate methods/materials/and or actions to meet codes
Conducts field inspections of foundations, framing, plumbing, mechanical, and electrical for code compliance and life safety provisions, composes clear, legible and thorough inspection records for diverse audiences and building staff.
Trains and gives general direction to other employees when applicable
Performs related duties, as required
May be reassigned during emergency situations
Required Qualifications
PLEASE NOTE : When submitting your application, be sure to include all relevant education and experience, as applications are screened based on the qualifications listed in this position announcement. Applications that do not appear to meet minimum qualifications, as outlined below, will not be considered. Resumes are not accepted in lieu of completed applications.
Please be aware that your cover letter and resume will not be accessed in the initial screening process, so you must complete your application and supplemental questions with as much detail as possible. Any personally identifiable information (PII) such as name and address will be redacted from applications that meet the minimum screening requirements and are forwarded to the hiring manager. If the hiring manager selects you to advance in the hiring process, your cover letter and resume will then be accessible to the hiring team.
EDUCATION AND EXPERIENCE:
Boulder County is looking for well-qualified candidates to fill our positions. In this position, we are looking for a minimum of a high school diploma or equivalent and four years of experience working in the building trades . Additional related education may county toward required experience.
LICENSE REQUIREMENTS:
Applicants must hold a State of Colorado Journeyman or Master Electrician’s license or be able to obtain a State Electrical License prior to starting
Current International Code Council (ICC) Residential combination Inspector Certifications or be able to acquire residential building and plumbing certifications within the first year of employment
Must possess a valid Colorado Drivers License prior to first date of employment
BACKGROUND CHECK:
- Applicants must pass a criminal background check
Supplemental Information
PREFERRED QUALIFICATIONS:
Bilingual in Spanish and English
Considerable knowledge of modern building construction methods and practices, and appropriate building and electrical codes and ordinances
Ability to detect hazards and violations and recommend corrective action
Ability to understand plans, blueprints and specifications, and compare them with construction in progress
Ability to obtain ICC certifications in the International Building, Mechanical and Plumbing Codes and the National Electrical Code
Ability to work independently on field inspections and make decisions exercising technical judgement. Consults with supervisor on more difficult and unusual cases
Ability to work effectively with other employees and the public
PHYSICAL REQUIREMENTS:
Performs physical tasks associated with field data collection at a variety of construction sites that require lifting, carrying, pushing, pulling, or otherwise moving equipment and objects weighing up to 40 pounds. Traverses constructions sites, i.e. walking on uneven terrain, cross fences, climb ladders, and operate a vehicle to field locations. Requires the use of close and distant vision, peripheral vision, depth perception and the ability to adjust focus.
