All,
Look at the attached pictures, Appears a jumper off main grounding cable and cable isn’t connected to ground rod. A first look for me. Is the effective grounding?
Is the main ground wire connected to the rod?
I can’t think of any way that can be right…
No. main wire is disconnected and had jumper that was buried in ground attached to something?
Since it is hard to see.
“Loose wires. Properly secure and verify proper connection/termination.”
No it ain’t correct it’s an issue write it up.
The other jumpers probably for the cable TV guy.
Thanks. I appreciate the replies.
