Electrical inspection without removing deadfront
Im going through the training courses and having trouble wrapping my head around somethings in the electrical section. An inspector isnt required to remove the deadfront, and probably shouldnt, but theres SOO much that should/could be inspected. How can inspect the grounding/bonding, or doubetapping or even if the wires are aluminum with removing things?
You can’t. That’s why so many inspectors remove the deadfront.
Not required to remove it not the same as being prohibited from removing it. Just keep in mind if there is state or local SOP that governs home inspections you may be required to inspect the inside of the panel.
You cannot and that is not really your question.
The question is “am I providing an adequate service without removing the cover?”
This is a debatable topic. If falls in line with walking roofs, traversing attics, or digging deep into a crawlspace." You will have to decide what type of inspector you will become based on your skill level/training, state requirements, and integrity/character.
You can’t.
But, if there is what you consider a safety issue with removing the cover or you can’t access it, you’re not required to remove it. Just be sure to document the reason why in your report.
The same logic can be applied to walking roofs or any other part of the inspection that you feel could endanger you.
you are right, i know when i had my first house inspected years ago, i was mainly concerned with moisture and electrical. i would feel like i wasn’t being adequate with removing the cover.
I have had the situation with the breakers in a old FPE sub panel, where the breakers felt and looked to be pushing the cover away from the box when loosening the cover screws, obviously for safety reasons I didn’t remove that cover, loose breakers are not safe but you document it in your report and move on.
No reason to hurt yourself to do your job.
