Electrical Load Calculation
Wait for some of our resident experts to chime in before you take that to the bank. They will likely have much better information.
That’s the problem. You are closed minded to those you have issue with.
I don’t care about proper message board etiquette such as posting links to other threads. You can continue to pick up my slack though.
Thank you for that.
I found it interesting that Juan had to start another thread just to accept the opinion already offered in the other thread, without waiting for benefit of further input from others.
Will do
Dang. I guess I made another message board mistake. Thanks for keeping me honest Jeff.
There is a good talk about Load Calculations in the book talked about in this thread :slight_smile:
http://www.nachi.org/forum/f2/electrical-inspection-code-check-85217/
Normally, as Jeff has stated, it is done at the design phase before construction is begun. This is typical of both new construction and renovation projects.
Thanks Will.
Sometimes it’s good to start another thread just to get your question separated from all the useless and unrelated-to-the-topic posts.(Like my post in this thread for example) :smiley:
That is what I was thinking. Perhaps we just don’t know how to use the message board properly.
I have a load calculation form in excel, if you wan tit.
Just e mail me@ ev@magnuminspections.com
You do this on a home inspection?
I only did load calculations when in the back up generator industry. Why would a Home Inspector ever need to do a load calculation anyway, except for the obvious.
I inspected a 1500 sq ft home not long ago, where the old fuse box had obviously been replaced by a breaker box. It contained 5 total circuits. No calculation necessary…
That doesn’t sound like a design or rehab/reno event to me. Why the load calc when installing a generator back-up system?
to properly size the back up power needed. Some wanted full electrical capability, some only partial. Most telephone offices were only back up for the batteries that operated their equipment, and a few lights. Others wanted entire building, un-interrupted, and many homeowner customers were the same.
One thing was always consistent. The partial people ALWAYS called back wanting to add more load to the generator…
No, just offering the form.
Thanks for the info.
You’re quite welcome Jeff. Here’s some more totally useless info you would never use for a home inspection: Given a home that is 200A service, people would think they need a generator that is capable of producing 200 amps. AxV=W, so that is about 48KW. I have never, ever measured a home that was drawing more than about 80-90 amps, even when everything was running at once (The heat and air conditioner never run at the same time).
About a 20KW is all anyone would ever need, unless they have an enormous house with more than one service, pool heaters, etc.
I ran my whole house (without air conditioner) for 6 days straight on a 6KW portable gasoline generator.
That is correct Jeff, but to just add to it, this also applies to Commercial not just residential.
I think when I mentioned Load Calculations in the other thread maybe the term got confusing to some. It really is nothing a typical home inspector should or will really ever need to use especially if they are not fully qualified and aware of exactly what it is, means and when it is applicable.
Although I do think between this and the other original thread some have learned a little bit about it and as I always say “Knowledge is your best tool” so really this has been a good healthy discussion as a little more knowledge can never hurt.
Jim
