Joe,
That is an excellent question! This would make a great discussion.
[FONT=Arial]*1. What is a grounding point(s) test?
*I’ve performed installation and testing in the past for military and commercial systems grounds. For our purposes we used the two and/or three pole ground testing methods at the grounding electrode, with the grounding electrode conductor obviously removed from the grounding electrode. A good article discussing this can be found at: [/FONT][size=2]http://ecmweb.com/mag/electric_putting_theory_practice/
[/size][FONT=Arial][FONT=Arial]2. What is an electrical outlet load test?
[/FONT][/FONT][FONT=Arial][FONT=Arial][FONT=Arial]3. What is an infrared main panel load test?[/FONT][/FONT][/FONT][FONT=Arial][FONT=Arial][FONT=Arial]
I’ve never had a need to perform load tests at the at the actual electrical outlet and obviously have not had a need to perform an infrared test at the main panel. I have, in the past, performed load testing for the main feeds, load testing at switching equipment and also at distribution panels. These have all required specialized, and actually calibrated, load banks and test equipment.
[/FONT][/FONT][/FONT]***[FONT=Arial][FONT=Arial][FONT=Arial]Are these services covered by any regulations, and do they include specific qualifications, such as licensing?[/FONT][/FONT][/FONT]***[FONT=Arial][FONT=Arial][FONT=Arial]
I know the NEC will certainly set the standards as to system performance requirements, i.e. a GE reading of <25 Ohms, etc. I know here in Texas these tests, if not performed by the structures owner or employee (in other words if contracted for) do fall under the purview of a licensed electrician to perform. No doubt this is something that we as HI’s should not be performing unless we are licensed as an electrician.
I’ve actually seen HI’s advertising these services on their WEB site. I found it interesting that with the thermal camera explosion I’ve also seen one HI advertise that they will load an entire panel to 80% capacity, let it cook and then perform a thermal scan for problems. I would certainly like to here from others who may perform, or have performed, any type of residential testing of these types. What I would be interested in is:
- What method are you using to test the residential system ground point?
- Are you testing loads at individual outlets and how? There appears to be some contention as to the accuracy and usefulness of the some commonly used test equipment such as the Suretest Circuit Analyzer.
- Has anyone actually performed load testing of residential panels and how was this accomplished and what equipment are you using?
It is, no doubt, a very interesting subject!
