Originally Posted By: jacaron This post was automatically imported from our archived forum.
I use the three prong Sperry tester. This tester checks for open ground, Hot/Neutral reverse , open neutral, open hot & hot & ground reverse. So far good. Although, lately ran into some discrepancies with the reading of open ground and hot/Neutral reverse. Is there any better or more reliable piece of equipment at a reasonable price that can do the job. I’m looking at the SureTest, however there are several types. Please advise?
Originally Posted By: Greg Fretwell This post was automatically imported from our archived forum.
The best way to describe a “failing” test is that there is something wrong. Simple testers will just give you a guess about what is wrong. If there is an open neutral conductor you will see strange things depending if there is a down stream load or not. Your tester will see the hot coming back down the neutral from the far end. For your purposes it is best to just say there is a problem, not trying to diagnose it.
