DO NOT DRAIN YOUR POOL
Your fiberglass pool is designed to remain full of water at all times. If the pool is drained without proper directions, hydrostatic or ground pressure outside the pool could cause the structure to buckle or crack. All damage to the pool shell resulting from improper pool drainage is the owners responsibility. If it becomes necessary to drain the pool, contact your Dealer or Pool manufacturer.
installed for san juan pools, parkhill & dolphin back in the day
installed for san juan, parkhill & dolphin pools back in the day
Anyone having swimming pool, hot tub or spa problems with their residential or commercial properties is free to contact me at 972-487-5634
Barry is right on here. Even non fiberglass pools can be effected by hydrostatic pressure. Often in a concrete pool when work is being done a couple holes will be drilled in the bottom of the pool to keep the water from pushing it up. Hydrostatic forces can be 10x more than dirt alone.
To add to what others have said, these pools can float up out of the ground if the soil gets saturated. As said NEVER DRAIN A POOL without some input from a professional.
