Need help trying to determine the size and Age of the Rheem evaporator coil.
SN: TM 3700 04471
MN RBHA- 21J18 MHACI
Can seem to find it.
Thank You
SN: TM 3700 04471
Thank You
1.5 ton it appears
2004 Maybe
What was on the compressor unit ?
Three Ton
Sorry : The condenser is a 3.5T
I would call the manufacture or dealer to determine the size of the coil . If it is under sized it will cause problems was there a problem during testing?
The data plate you’ve listed is for the AHU cabinet, not the evaporator coil.
Look for a second sticker on the outside, or inside the unit.
Dom.
The inside coil tonnage should match the outside unit
