Exhaust Pipe Drama
During a recent mold inspection, noted gap at exhaust pipe as a safety hazard. Homeowner booked an HVAC service call. HVAC tech tells homeowner that there is another pipe inside that metal outer jacket and its totally safe. Homeowner is now a little annoyed at me. Thanks in advance for your advice
The HVAC is correct that the standard is Type-L double-walled pipe. So, silver lining, going forward you will be on the alert for single-walled pipe as a defect.
How can I tell the difference between single & double walled?
If you look close in that gap you can probably see it…. poke your screwdriver in there (gently) and you should be able to feel it. Look downstream at any connections and they look different than single wall…. they usually have air intake holes to allow for cooling in the gap between pipes (assuming it’s not one of the 90% of the time the installer covered them with tape :slight_smile: )_
Sometimes double wall can be difficult to tell “for sure”. There is some more refined single wall pipe available. Get on line and look at pictures. When in doubt, use “appears to be”.
It’s embossed into the pipe. Also single wall pipe is usually installed with screws double wall pipe lock together. But anyways go visit your local hardware store and visit the HVAC section. Look at the pipes.
If the furnace is running and you have a thermal camera…
Remove the access cover and look ‘UP’!!
Generally, there are only “Double walls” on the exterior of the Furnace cabinet.
Learning curves can be expensive.
It will help everyone if you ask them for a copy of the invoice from the HVAC company so you could reimburse them.
Luckily they were out there for duct cleaning as well. Homeowner is a property developer with about 60 homes in the area, so if he has a question for an HVAC technician, they’ll usually check it out free of charge.
You were there for a mold inspection, why did you step outside of your lane? What does that condition have to do with mold?
Odor complaints
Maybe the inspector (though in this case making a rookie mistake) Would sleep better knowing a family wouldn’t wake up dead in the morning.
I would have recommended further evaluation by an hvac specialist as you did .As home inspectors we perform non invasive inspections . You did good .
