if you ever wondered the in’s and out’s of the panel installed in a detached structure then you may like this show. I was asked to do a small show minimum feeder sizes and the size of the disconnect in a detached strucuture type requirements.
YES…it is CODE ORIENTED…if you dont care about code…Then dont listen…!
Check it out here…
