Does anyone know about clearances on exterior A/C units?
I have a home that has two exterior A/C units only 6 inches apart. They are also under 12 inches from the home, resulting in poor air flow. Home owner says this is a non-issue, since his brother installed the units (you know how this is).
I have another home that has an exterior A/C right in front of the 200 amp meter. Specs? Thx.
200 amp meter requires 30 x 36" clearance, does it not?
Others may come up with different Mfg crap, but I have field tested and observed these clearances are required to prevent changes in equipment performance in the state of Tn.
Just looking for documentation for a disgruntled home owner.
CMI means that I do detailed reports, long in length, charge higher fees than any other inspector, alarm the home buyers of any defects, have a high rate of killing any deal, and are starving at the moment due to lack of business and competitors charging $199 to $249.
