Robert,
My comments about code inspections apply to #1 of the OIR-B1-1802 form.
Was the structure built in compliance with the Florida Building Code (FBC 2001 or later)?
The only people that can perform building code compliance inspections is the Building Offical and Building Code Inspectors and these people have to be certified/qualified in the proper category and Must be an employee of local governments or state agencies. The same applies to private providers. This is stated in FS and it takes precedence over anything else.
Florida Statutes partial
468.603Definitions.—As used in this part:
(2)“Building code inspector” means any of those employees of local governments or state agencies with building construction regulation responsibilities who themselves conduct inspections of building construction, erection, repair, addition, or alteration projects that require permitting indicating compliance with building, plumbing, mechanical, electrical, gas, fire prevention, energy, accessibility, and other construction codes as required by state law or municipal or county ordinance.
468.604Responsibilities of building code administrators, plans examiners, and inspectors.—
(1)It is the responsibility of the building code administrator or building official to administrate, supervise, direct, enforce, or perform the permitting and inspection of construction, alteration, repair, remodeling, or demolition of structures and the installation of building systems within the boundaries of their governmental jurisdiction, when permitting is required, to ensure compliance with the Florida Building Code and any applicable local technical amendment to the Florida Building Code. The building code administrator or building official shall faithfully perform these responsibilities without interference from any person. These responsibilities include:
They are required to ensure compliance with the Florida Code.
Question #1 on the 1802 form.
How can you the Home Inspector say that the structure was built in compliance with the Florida Code (FBC 2001 or later) when a majority of the items to be inspected during construction is now covered up or not visible?
And why would you want to assume that liability when someone else was required to ensure compliance with the building code and you are allowed to provide documentation of this.
2010 Florida Building Code (Building)
111.2 Certificate issued.
After the *building official *inspects the building or structure and finds no violations of the provisions of this code or other laws that are enforced by the department of building safety, the *building official *shall issue a certificate of occupancy that contains the following:
- The building *permit *number.
- The address of the structure.
- The name and address of the owner.
- A description of that portion of the structure for which the certificate is issued.
- A statement that the described portion of the structure has been inspected for compliance with the requirements of this code for the occupancy and division of occupancy and the use for which the proposed occupancy is classified.
110.1 General. (2010 Code)**
Construction or work for which a *permit *is required shall be subject to inspection by the *building official *and such construction or work shall remain accessible and exposed for inspection purposes until approved. Approval as a result of an inspection shall not be construed to be an approval of a violation of the provisions of this code or of other ordinances of the jurisdiction. Inspections presuming to give authority to violate or cancel the provisions of this code or of other ordinances of the jurisdiction shall not be valid.
To me, this means if we passed it on the inspection, it still might be wrong.
They are still required by FS to ensure compliance with the building code.
I provide copies of the CO or other signed off city/county/private provider inspections for determining compliance with the building code.
Home Inspectors can not perform building code inspections unless certifed/qualifed in the proper category and must be an employee of city/county/state government or employee of a private provider.
I agree that Home Inspectors should be knowledgeable in the building code. It will make you a better inspector, especially on newer homes. And if you find something wrong on these newer homes you can use the building code as reference material. You just can not perform building code inspections and should inform people of the difference.
Richard Haynes
