Looking for links with regard to the installation of a fiberglass gel coat finish on an exterior deck.
Thanks…
Thanks…
Here you go Joe. I have this on a large deck in Santa Barbara. This particular brand has a fiberglass base layer, and two top coats. It is over a plywood deck that had joints and edges flashed. Top coat comes in a variety of colors and usually lasts 8 years± or so before another finish coat needs applying. We have had it for 18 years with only one additional finish coat applied although it is time for another. Easy application and a good wear although with morning fog or evening dew it can get wet pretty quick.
Hi. Joe;
Don’t know if this is what you are looking for or not.
http://www.fiber-deck.com/prod01.htm
Marcel:)
Thanks for the links.
What I am looking for is additional links with regard to installation guidelines / recommendations / material specifications.
Appreciate the help.
Joe;
It would help if you were more explicit on what you are looking for.
Fiberglass Gels covers a lot of Territory, and makes a difference on the above requested.
Marcel
</IMG></IMG>
