Fiberglass vs Cellulose
Any insulation that allows air to blow through it is worthless.
Seal the attic and use spray foam.
Nuff said!
I have sold the TAP Insulation for another Pest Control employer a few years ago…
Where applicable, it was sold as a “cap layer” over existing fiberglass to provide additional insulation quality as well as the combined benefit for pest control…
your market may vary…
Spray foam is already a sealer, no reason to seal and spray…unless the installer just wants to increase the cost.
This has already been covered. Spray foam is not a good retrofit product for walls, so it is not an end all. For new construction ICF is a way better product and about the same cost. Add to that I Form, which is also a way better product at approx the same cost. If we are talking just attic, then yeah spray foam is the best product.
JJ
Wet-Sprayed Cellulose Insulation in Wood-Frame Construction
no big surprise
Thanks for sharing this article, very good reading. I would just like to add that the cellulose insulations available these days have lower flame-spread ratings than fiberglass insulation. To illustrate: Fire Testing Insulation Materials https://www.youtube.com/watch?v=8NC79e0oztM
Please note that the test shown in this video is just for illustration purposes only and is not a standard test like the “CAN/ULC-S102, Test for Surface Burning Characteristics of Building Materials and Assemblies”.
Whats this topic about I can’t get it
