Originally Posted By: mlong This post was automatically imported from our archived forum.
Does anyone know anything about HVAC units manufactured by Fireless Furnace, Inc.,manufactured in Fullerton, CA? Saw one today, no problem with it, but I’m just curious. The system had an A/C compressor, with an air handler inside of a closet. (Difficult to access). At first I thought it was a heat pump, but then I saw two water lines, one in and one out, like the type that are used to heat flooring. The crazy thing was, when I turned the heat thermostat up, I felt heat coming out of the forced air registers. Not sure what was going on here, but since I had heat and I had cool, I was’t too concerned about it. Just want to learn a little bit more.
Originally Posted By: rcooke This post was automatically imported from our archived forum.
Sounds like a water powered heat pump using underground water . Depending on you area the water should be about 50 + degrees. It works similar to an air heat pump but much more efficiently . They use a liquid in the lines ( Salt water I think and it goes in a continuos circle from down in the ground )
Originally Posted By: bgentry This post was automatically imported from our archived forum.
GoeThermal Heat Pump. They work much better that conventional heat pumps in colder weather because the water in the lines stays a constant temperature all year.
A GeoThermal Heat Pump makes sense. The only thing that causes me doubt is that this is in a townhouse with a relatively small backyard, but I suppose it’s possible. I’m just surprised to see it here.
