First time seeing this. Please explain
In the attic yesterday. House was built in 1967. Top photo to the left was the exterior wall.
need a wider view.
Was there something mounted/ hanging on the exterior of that wall?
Beginning courses (4 ft stabilizer) of/for new roof Rafters.
Nothing on the exterior outside view of wall.
Gable wall bracing is my WAG.
I’ve seen one time where the homeowner tried to stablize a leaning chimney by tying it to the rafters :rofl:
That’s called a “witch’s bend” around here! Gotta keep them witchs from flyin’ down your chimney!
No, I wasn’t talking about a witches bend. It was a chimney at the side of the house that was separating and they bolted it to the rafters.
Ah,
like this one! So much daylight and cold air was coming in around the vain attempt at flashing it was not salvageable. Problem originated from a failing fireplace pad. As the concrete pad disintegrated the entire fireplace was pulling away from the house. Still standing today the house no longer has a fireplace and is no longer as drafty!
My WAG is that that it’s supporting something or stabilizing something on the exterior side of the wall.
Do you remember what was on the exterior side of that wall, Peter @pgiannino ?
My thought as well.
There was nothing on the exterior wall that this could have been attached to.
If you actually look at the pictures, you can see whatever the bolts were attached to on the outside of the structure was likely removed, the bolts lost tension and moved back into the house, hence the the gap between the washers and the rafters AND the washer shaped discoloration on the wood rafters indicating previous location of the washers.
I still think there was a chimney that was leaning, metal straps were wrapped around the chimney and attached to the rafters with bolts, then either the roof framing started to look wonky or someone saw that stupidity and told the homeowner it’s not going to work. Then the homeowner got quoted a massive cost for jacking the chimney footing up or replacing the chimney as a whole. Ended up going with the cheaper option of cutting the straps, removing the chimney, and patching the wall.
Looks like blocking and bracing to hold the rafters in place while the sheathing was being put down.
