Anyone else receive this email? I reaks of fraud or phishing…
Hello
I need the services of your company
Your company will be inspecting some homes for me
The homes are located in Baraboo
Please note the following below
**1, **All the pictures for the inspection must be computerised and the report
Will be in PDF format ok
2, STRUCTURE: foundation, crawlspace, footings & columns, floors, walls,
chimneys.
3, ROOFING: structure, coverings, flashings, skylights, vent/stacks.
ELECTRICAL: service entrance, grounding, panel & sub panels, branch
circuits, outlets, GFCI’s, circuit integrity.
4, HEATING and A/C: description, combustion system, A/C components, supply
& discharge lines, venting, duct work & registers, controls &
thermostats.
5, PLUMBING: main supply line, distribution lines, fixtures, vents & traps
& drains, functional flow.
6, INSULATION: attic, walls, crawlspace, floors, lines, duct work, air &
vapor barriers.
ALSO TEST THE FOLLOWING
Water Quality test for the 6 homes
Septic inspection only for the 6 homes
Septic inspection and pump for the 6 homes
Radon Testing for the 6 homes
Well inspection for the 4 homes
HOUSE DETAILS
a, Total number of homes to be inspected… 6 homes
b, Total sqf for** 4** homes 3500… 4500 Respectively
c, Total Sqf for the remaning** 2** homes is 4500… 5000 Respectively
d, All the 6 homes are above 17 years old
NOTE
The inspection must be according to ASHI standard
Please give me the total cost for the inspection of the six(6) homes according to the informations provided.
Hope to hear from you soon
Regards
Fidel Fernando
