Flashing of decorative panel below windows
Saw these fiber cement board panels below windows on a new Tennessee home with vinyl siding. The panels were nailed on. Should I expect to see some sort of cap flashing on the tops of these panels? It looks as if water can get behind the panels and possibly infiltrate at the point where the nails are.
Appreciate your thoughts!
I would agree with you, flashing would be prudent there. Must be mounting areas for window boxes?
You’re way off there Bubba! This is Tennessee and those are pop-out panels for gun ports! Of course I still agree with your flashing assessment.
:rofl: :rofl:
I agree with you. Anywhere I see horizontal material that protrudes or can allow water entry, I look for flashing.
I’m wondering if this is an old window with a stool and apron that were left in place from a retrofit window installation. Then, as an afterthought, they may have decided to fill it in because the wood was rotting away. It would be nice to be able to talk to the installer. And yes, the flashing is missing.
I originally thought the same Allen, until I remembered reading this:
Good thinking though, IMHO. :+1:
In California guns are a big no-no thanks for helping me understand Tennessee culture.
It literally just a piece of decorative trim they tried to integrate into the wall to make the house look a little better.
The new construction window has a bottom nailing flange…How are you going to magically flash the little piece of trim if the trim physically covers the bottom nailing flange of the window? You can’t really put flashing there, unless you move the trim way below the window, leave a gap between the window flange and the trim, insert the flashing under the nailing flange and into the window sill area…all this would have to be done before the window is even installed. But then you have to leave the bottom flange of the window open for drainage so you can’t cover/flash it at the end. Now you’re left with a fully exposed window bottom nailing flange.
Why are you worried so much about the tiny trim nails but are not concerned about the 6 large screws used to fasten the decorative shutters at the sides of the windows? or the bazillions of siding nails going through the housewrap?
At this point, you can caulk around the joints of the little trim and call it a day, or you remove it all together and replace the batten siding under the window and also remove the decrorative shutters and replace those siding pieces while you’re at it since they have exposed face screws too. Now you have a bald looking wall with bland vinyl siding, but hey…the wall is now slightly more water resistant than before. Pretty sure the homeowners won’t like it and are probably going to get fined by the HOA for doing that.
We can keep going on this tangent and just decide to not use vinyl siding in the first place because, as you know, it is a loose siding system and rain water will get behind the siding through the lap joints, between end joints and J-trim, and so on, especially during wind driven rain, which can potentially rust all the siding nails going through the housewrap and wall and potentially leak right?
