I did an inspection on a single family home. The roof is a built up roof , less than 2:12. I am filling out the Uniform Mitigation Verification Inspection Form and on section 5 - Roof Geometry I am not sure if I should check off option B) Flat Roof (Roof on a building with 5 or more units…etc) or option C) Other Roof (Any roof that does not qualify as A or B. My confusion is that this is a single family home with a flat roof, not a building with 5 or more units. I assume it is then C but not sure.
If it’s a SFR, then it’s not a “building with 5 or more units”.
The correct choice is C, other roof.
Dom.
You assume correctly
