Wondering if anyone here has owned a FLIR ONE Gen 3 - Thermal Imaging Camera for Android Smartphones (USB-C). If so, were you satisfied with it, or did it not meet your needs and expectations? My initial interest stems from how easy it would be to load thermal images directly into my home inspection sofware on my android phone out in the field.
If you were not satisfied with this thermal imaging camera, what did you end up getting to work with your android phone?
Michael, good morning.
You say you want to load thermal images ‘directly’ into my home inspection software. Do you know how to read a thermogram let alone a thermogram with such limited information?
It cost a couple of thousand dollars to invest in infrared thermal imaging software, unless things, software has radically changed. Typically all inclusive infrared imaging software costs thousands of dollars to purchase.
A good handheld infrared camera cost between 2 and 3 thousand dollars.
Simple specs for GEN 3 Flir One: resolution of 80x60 and a temperature range of -20°C to 120°C (-4°F to 248°F) Why would you scrape by with the resolution of 80x60?
I had one a few years ago (probably not Gen 3 though) and it was trash. Constant crashing and then the battery stopped holding a charge. Traded it for a new one under warranty then promptly sold the new one on eBay without even opening it.
Regarding your questions: I’ve been doing home inspections full time since 1993, and probably won’t be doing home inpspections for much longer (I’m 73 now). When thermal imaging cameras first came on the scene early in my careers, they were in the $14K range, which was shocking.
Of course over the years, I’ve sat in on quite a number of thermal imaging presentations at seminars and conferences. And, I’ve taken both of the Thermal Imaging coursed here on the INTERnachi web site. I’m not planning to add thermal imaging as a stand-alone high tech service. I am more thinking it would be helpful to pull one out now and then to confirm moisture intrusion and plumbing leaks with a thermal camera adequate for this rather limited purpose along with a moisture meter. I own an hti HT-A1, which seems to do the trick, but transfering images into my software is a pain.
Again, I understand completely and do appreciate what you are suggesting, but spending thousands of dollars on a thermal camera for what I plan do do with one, probably doesn’t make sense.
Of course I’m open to what others have to say, but again, I’m not interested in getting heavilly into thermal imaging as a add-on or stand-alone service. If the FLIF ONE Gen 3 unit is woefully inadequate even for my limited intended use, that’s good to know and I’m open to suggestions.
I bought a hacked E4 (hacked to E8) off eBay. Best bang for the buck at that time. I hear lots of good stuff about Hikmicro nowadays though. So would probably be looking at those pretty hard when I need a new one.
Yup. For the price and for what I use it for, it’s perfect. I use it on every inspection. Hikmicro Pocket 2. I also have a little usbc camera that is my backup, but haven’t needed it.
You should not be putting scans into your report. You are not tuning them so you don’t know what you can’t see. It is also evidence for a liability complaint.
You can use it as a glorified flashlight to see air, water, plumbing traps, hvac registers connected etc. Then go look for the cause and take a digital pic to put in the report.
I don’t see a scan download option in the 12 page manual.
Interesting, David! So generally speaking, home inspectors don’t typically include thermal images in their report, they just use it to help them arrive at a conclusion? Is that what you’re saying? I’ve rarely used my thermal imaging camera, so I’m not familiar with the generally accepted protocols. But, I’m interested in adding it’s use as a part of the process of elimination.
Michael G. Bryan
President,
Inspection Services of Central Virginia, LLC
(804) 744-0380
Virginia State Certified Home Inspector
VA Lic. # 3380000608-NRS (Expiration Date 1/31/2027)
InterNACHI CPI - #17120503
Member of the Virginia Association of Real Estate Inspectors (VAREI) John 1:12-13
As i said earlier, Im just exploring the prospect of using thermal imaging in some capacity, but haven’t really gotten as far as SOPs in regards to thermal imaging. For most of my career I’ve been adhering to originally NAHU, but later NACHI, ASHI, and of course my Virginia DPOR regs. (After a couple decades of membership, I’m no longer an ASHI member).
I have purchased two FLIR C5 cameras from Facebook Marketplace for $300 each. I include images in my reports, but you are just going beyond the scope and adding value to your inspections. You will need to take the training so you understand what you are looking at first, as you can get into trouble quickly.
When I started TI years ago when these cameras first came out as an affordable option, I used the camera to find things I could not see. I then stopped what I was going and went back to physically inspect the components that looked off. I would visually verify what was showing up in the camera, or not. I did not have the needed training yet, so I was acquiring “experience” of what the camera was showing. Over time, I got the training and experience to put IR in the report. But still only if I could visually access and verify what I thought I was seeing.
This is what I am recommending, and the reason is Liability.
If you’re not capable to properly analyze the Thermal Exceptions you’re putting in a report, and you’re wrong when they get the hammers and saws out, you’re in a bind.
Blue is not always water, and Red is not always an overloaded electrical device. How hot is too hot? What is it supposed to look like if it is a defect? Are you capable to make these calls yet? If not, I don’t recommend you put this stuff in the report. After all, if you don’t find it with thermal imaging and don’t call it out the problem, your covered by your SOP for things that are not accessable, or visually apparent.
