Florida Wind Mit Inspection Template 2026
Here is the new 2026 Wind Mit template for HIP.
I’ve haven’t checked or used it yet.
ALSO ICYMI…
Just using it for the first time tonight, because an insurance company already rejected the previous one.
I was trying to google a wind map, and they are all over the place. My area (hillsborough and Pinellas) appear to be 140-150mph, but some older ones have around 120.
It also asks for the roof slope now..
Say hello to my lil friend :slightly_smiling_face:
This is the topic for the next zoom meeting Tampa Chapter.
Thanks, thats pretty cool.
But I cant get results unless I select a risk level.. Which changes the wind speed.
For example, the address I put in has either a 134 wind on risk 1, or a 144 on risk 2.. But How do I know which one to select?
I haven’t checked this…
Risk Category is ll (two).
Something else that is annoying about the new form is that you have to select either a full self adhering SWR, or the Tape over the seams.. But we have no way of knowing which it is, when we can only check at the seams.
Most (if not all) SFH’s are Risk Cat ll. Cat l is like Ag building/barns ect. Cat lll is larger residential or commercial like churches etc. Cat lV is essential structures like hospitals etc.
There’s a wind mitigation class coming up on the 11th in Sarasota. Well worth it and can get all your questions answered.
For the slope, you can use a Johnson’s pitch and slope tool or you can use an app. But if you didn’t take it at the time of the inspection, you’ll have to go back.
For the SWR they suggested that you check the ridge vent, if you can see it in the ridge It’s probably fully adhered peel and sick because they won’t tape the ridge.
Haven’t really had any questions until now, haha. New report is much more detailed. Last one would literally take me 3 minutes to fill out. This one will get there too, just more changes than I expected to see.
I hear you. We do a ton of wind mits so going to the class was worth it for us. Happy to share info. Hit me up if I can help.
Not so fast…ALL of Miami-Dade and Broward Counties are HVHZ zones.
