Forced Air Hot Water System
I need help!
Installation date was 2002. Installer is long gone!
Hot water forced air system. The heat exchanger coil and the A.C. coil are ADP. The water heater is a Bradford White 73 gallon unit.
The drinking water and water heater and in floor radian heat are all in one package. Does to-day’s requirement require the drinking water to be seperate. I think it does. Is there a time limit or are existing systems grandfathered.
Any input at all will be welcome.
Regards:
Bryce Jeffrey
Check with the AHJ about the requirement.
http://www.bradfordwhite.com/products_gascombo_res_nat.asp
