I work for a builder in oregon and we are using Fossilcrete verticl stamp mix as a waterproofing agent on the exterior of ICF forms. The local city building officials are requesting proof that the product is waterproof in the form of test results. I received a permeability test unter ASTM E 96-05 (Water Vapor Transmission) as well as Freeze-Thaw and Flexural Strength test results. Will any of these provide the officials with the information needed or must I keep digging??
Matt,
You might get some good feed back here!
http://forums.jlconline.com/forums/index.php
Make sure you fill out your profile they get grumpy if they think you are a DIY!
If you would be so kind post the info back here so everyone can see about the product.
