Got milk? https://www.youtube.com/watch?v=VOJyov5oCXg
4:00 at least a partial interior basement system installed that does nothing to stop water from entering the exterior cracks in block walls and does nothing to relieve, remove exterior weight/pressure, underground roots off failing walls
5:15 sump pump, again, does nothing to stop water that has been entering exterior cracks for many years and does nothing to relieve/remove exterior weight,pressure, clay,roots
6:05… and 7:00 trees = roots, roots can also dry-out the soil which can cause foundation problems
20:30 and 21:40 chimney, he says ‘chimney is moving (cracking)’ and points to both sides.
umm, IF that chimney is moving aka IF cracks have occurred on the SIDES where he points to then it’s very likely those cracks extend DOWN to/towards the footing hence, he needs to at least CHECK that possibility and remove the visqueen etc in order to check and then, if necessary, seal/hydraulic cement those cracks!!! loolll omfg he says NOTHING about that, doesn’t utter one damn word about the possibility. Why not? He spent a half friggin hour on the video, whats a few more seconds!! morons all over.
Yeah, he IS right about quite a few CITY inspectors… they suck on this subject, incompetent, yeppers
