Free Contour Map Program
Attached is a free HTML app I had Claude AI build that draws contour maps based on the coordinate data you input. I compaired it to commercial software I use and it does a great job. Just download the file and double click it to run. FIY - It took 14 attempts to get the bugs worked out.
It automaticaly loads the built-in sample data to see what the contour map looks like. Just clear the sample data and type or paste in your data. The Boundry Polygon data is optional, but it clips the contour map to fit a non retangular shape area by entering the X,Y coordinates of the perimeter of the room. (i.e. a L-shape room)
RLM Contour Map v2.html (52.3 KB)
NOTE 1: When using a Zip-Level it will give readings as pluse or minus, because the base unit location is considered zero elevation. Enter the Z coordinate with the actual +/- reading.
NOTE 2: Using a Hilti or other laser levels, typically on a tripod, the laser line is considered zero elevation. So the distance from the floor up to the laser line should be entered as a negative number. Measuring from the ceiling or subfloor down to the laser line should be entered as a positive number.
only 14 tries? it usually takes 20 or so for me to work the bugs out. once it made something that worked the first time, but that was a simple thing. thanx for sharing.
Hmmm I wonder if AI is capable of writing a topography mapping function for land using a smart phone? That can be real handy to have!
it could use this one since it’a an html webpage if i’m not mistaken. it just needs to be on a server from the look of it. i have yet to try it out although it looks cool as hell.
You just need Google Chrome or similar browser on your computer. Then double click the HTML file I sent and it should run.
