I have had these extra parts sitting around for a while. I have moved on the newer drones so I don’t think I’ll ever use these parts again. Free to a good home.
Compatible with the DJI Air2 and Air2s drone.
3 batteries, controller, hardshell case, power hub adaptor (charge your phone or flashlight or whatever from the batteries.)
Not to put a damper on a free giveaway, but I just had to ditch all my Mavic Air 2 batteries due to an almost un-noticable issue until it became an issue. They were 5 years old with moderate use / charging.
I was inspecting a 2-story roof with my Mavic Air 2 a couple weeks ago and everything seemed fine until I landed the drone. The battery had swelled enough to disengage the locking mechanism and was just barely making contact to power the drone. Another couple mm’s of swelling would have disconnected the drone and it would have dropped onto the roof and the battery could have gone anywhere including into the gutter and caught fire if it became damaged. A lithium battery fire in a gutter on a 2-story roof would have been really bad.
I didn’t know what to do with the battery because I didn’t know if it was going to explode or catch fire or not so I called the FD. I noticed my other two batteries also appeared curved/swollen after 5 years of use. I took the batteries to hazardous waste drop off right after my inspection. If the flat side opposite of the button is curved in any way, it might be time to ditch them.
I am not worried on the batteries or swelling…I have a few already. These will be more used on trying to get some good Orca shots out on the Puget Sound. It is a different perspective! Texting over to you in 5!
