Friday's follies
Originally Posted By: gmagee
http://www.nachi.org/bbsystem/usrimages/more/P1010114%20(Small).JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/more/P1010082%20(Small).JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/more/P1010119%20(Small).JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/more/P1010124%20(Small).JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/more/P1010154%20(Small).JPG ]
First is the main disconnect
Second is a Zinsco panel in a closet
Third is a Sylvania in a garage
Fourth is another Sylvania in a crawlspace 20 feet from the last one
Fifth, and finally, the last Sylvania in another garage 60 feet from the others
Originally Posted By: rpalac
What is wrong with the first three pictures?
The last two are obvious..... cabling improperly connected, open holes larger than 1/4" and open panel fronts.
Maybe I'm still asleep.
Bob P.
Also I'll bet none of them are labled....I always seem to write that up
Hi Bob,
I had briefly looked at the exterior main disconnect on my way into the house. Inside (the place was not completed from a project started years before) I found lots of receptacles without covers, lights dangling from wires, no GFCI anywhere and other stuff that would suggest that a licensed electrician should take a look.
The panel in the closet had neutrals and grounds connected at the lower portion - didn’t seem right with the main located outside - probably need to have this looked at. Also two wires connected to a 15 amp breaker. Anyway, after finding this situation, I get to the garages and crawlspace to find three more panels, all Sylvania. Two without covers, one with.
There were so many cables (not supported properly) that I did not try to sort any of it out. Just a weird Friday inspection!
Some times we do get into overwhelming situations.
I guess it looked like a monster house that was abonded during the show.......
