cbottger
(Charley L. Bottger)
February 9, 2013, 1:58am
or not, for those of you that just operate a furnace from the thermostat would you call this temp discharge on this electrical furnace sufficient to make the call that this furnace was performing as intended???
cbottger
February 10, 2013, 2:53am
2
90 lookers no replys I thought this org had inspectors:D:p whats the deal cat got your typing finger;-)
belliott
(Bob Elliott, 450.0002662)
February 10, 2013, 2:56am
3
I posted one hour before you actually looking for help,did you reply Charlie or to busy ?
My post is a real question rather than SEO booster so not worthy ?
cbottger
February 10, 2013, 3:04am
4
belliott:
you have lost me this is just a question about ele furnaces no SEO on this just the dry set
Yes I have been busy getting wife out of hospital and running back and forth 85 miles to hospital been a wild week
belliott
February 10, 2013, 3:24am
5
cbottger
February 10, 2013, 3:45am
7
mgratton:
tooo hot…
What is to hot, your a man of many words
mgratton
(Marcel Gratton, CMI)
February 10, 2013, 4:07am
8
got the F mixed up with the C…
Actualy, if there is 2 heat strips its working as intended but if there is 3 heat strips, one heat strip is not, assuming that the room temperature is around 70 degrees F.
cbottger
February 10, 2013, 12:43pm
9
mgratton:
That would be correct 3 strips one not working:D did not need the amp meter for this one;-)
