Gallons of water locked up aka trapped inside several blocks, basement
and it FIRST entered into these blocks outside through a couple cracks in basement walls and big gap under basement window sill - don’t let the moron INT system terds fool you aka lie to you, 99% of water inside blocks first gets into them on the exterior
‘philosophers and ploughmen each must know his part
to sow a new mentality closer to the heart’
now you gettin’ it Mr Hardware man
https://www.mrhardware.com/articles-and-videos/cement-block-and-water/
…‘For this reason i don’t promote basement waterproofing systems that collect water with inside gutters, nor do i think cutting the basement floor and installing drain tiles a very good solution, cure the problem, don’t treat the symptom’
