Two newer houses this weekend (2002 & 2004). Both had the screw drive type openers. Neither safety reverses worked, however, both had the “eyes”. Now, do the screw drive type normally have the SR feature? I’m assuming they all do, however, now I’m wondering. Thanks in advance for helpful replies.
Probably present, but the sensitivity is not adjusted correctly.
“The garage door opener is functional, but it does not auto-reverse when it meets reasonable resistance during closing. The mechanism is either absent or it may need to be adjusted. Failure to service this defect may result in death or personal injury to small children or pets.”
Sometimes the sensitivity needs to be adjusted at the unit. Sensitivity can be affecteed by temperature and sometimes they’re very difficult to get adjusted correctly.
