Hey FL guys! Can you help me out?
Will the following meet the necessary requirements that are needed in FL for replacing my Mom’s garage overhead door (IE: wind, impact resistance and whatever else is needed)?
See below for specs:
**Doors:** **Amarr – Stratford 2000 Series: ****25**Ga. Hot-Dipped galvanized steel skinw/ Vinyl Back EPS (Expanded Polystyrene) Foam inserts, 6.84 R-Value. Raised Panel Designs, Torsion Springs, White PVC – Vinyl Door-Stop Molding, Bottom Astragal Weather-Seal. 25-Year Ltd. Factory Warranty on Door Sections, Paint finish & 2-Year Warranty on Hardware. Doors come factory-finished white, additional paint can be applied. Oil Base paints are not allowed. Refer to Amarr painting instructions for more information.
Wind-Load: ** Wind-Load: 168 MPH Exposure Category “B” Enclosed Structure. **Engineer Shop Drawing# IRC-6009-130-15-I. Design Wind Pressures (PSF): +26.7 / -31.6. Test PSF = 150% of Design PSF. Impact Resistant. FL# 13521
I appreciate any accurate help, as I know nothing of the requirements being from MI, myself.
Thanks…
