Gas Leak Protocol?
Do any of you test for gas leaks and if so what is your protocol if you find a leak? Do you stop the inspection and vacate the home? Do you notify the seller/listing agent? Just curious what should happen if a gas leak is found
Yes, yes and call the appropriate authorities if it’s an immediate safety issue.
Your nose will be your best instrument for detection. Once you smell a leak, identify where the leak is coming from if you can. Identify the defect in your report. Move on.
If you smell a leak during your inspection, chances are it’s been leaking for a very long time. There’s no reason to panic. Most gas leaks are very small.
I find them at least once or twice a month on water heaters and furnaces.
Every time a gas appliance turns on and off there is a small amount of gas that puffs out of the regulator. No reason to lose your head.
I light a match and try to find out where it is!
I’m with Martin. Gas leaks are common and only once have I seen one that I called the gas company on.
Ditto… and the only one I ever called the Gas Co. on… was one that when I opened the front door, the odor nearly knocked me on my arse!! My next call was to the Buyer Agent who notified the Seller Agent whom I assume notified the Seller. Shortly after I hung up with the Agent, the Fire Dept. showed up and began their process of ventilating the home and testing for leak(s). They advised me it would/could be a couple or more hours depending what they find, and suggested I reschedule the inspection for another day.
Of course, the Agents were pissed, but who gives a phuc? Not me!!
Exactly… Do not freakout over a small gas leak.
I had only 1 very noticeable gas leak and it was on the exterior of the home at the meter, noticed it while doing the review with the client, I called the gas company, and they came out and fixed it then surprisingly called me shortly after I had left the property to let me know that they had done so, probably within an hour of calling them.
Hope you’re a better inspector than comedian
Never had the situation… However, if you suspect a major gas leak, the safest thing would be to stop the inspection and call the gas company.
I had one on the exterior, but not at the meter. It was coming from underground. We contacted the gas company and in about 15 minutes they were there with their “fancy” gas detectors. It was about 6’ from the meter towards the main feeder. They turned off the gas to the meter, flagged the area and left. A new crew was there in about 30 minutes and started digging.
I’ve had three instances where I told them to call someone ASAP. All three times new construction, the gas company was there before the inspection was finished. Many other times I’ve smelt gas but didn’t feel the need to call anyone. I carry a spray bottle of bubbles JIC I need it.
Did it make a hissing sound?
That’s one of the items the gas company lists on their newsletters what to hear or watch out for
No hissing. I think that is going to be on the high pressure transport lines.
Around 20 years ago, I had to replace my sanitary sewer from the home to the main. Long story, but the city paid for it. Because of everything that lead up to the replacement, I made sure I was there for the project.
The backhoe operator had just been released from prison. Certainly not his first visit or his last. He spent most of the day telling his coworkers all the great things he has learned while being locked up. The one subject that still sticks out is about how to blow up a house using the existing gas piping and large appliances, without leaving any clues. It does not take much.
in 2007 i ran over a 2" gas line that was stubbed off about 6" above the ground in high grass with a lawn mower. made a hell of a noise and scared the shit out of me. as soon as i hit it i let go of the handle that stops the mower and pulled it back about 10’ then ran into the house to call the gas company. then i went back out and waited to keep folks away from it if anyone should come see what the noise was. i thought for sure it would’ve done something but i am damned glad real life isn’t like the movies.
Your action should depend on the severity of the leak. Don’t downplay the severity of a leak based on anecdotal experiences from other inspectors. You must understand the specific properties of the fuel gas type present, its lower and upper explosive limits, and the rate that the gas could cause asphyxiation.
A small release of gas is normal when an appliance fires up. Micro leaks are also normal but quickly disperse in a well ventilated space. These leaks should not present an immediate hazard and should be reported accordingly.
But, if you enter a home or a room and you’re overcome by a strong gas smell, you are not obligated to proceed, especially if you do not know the concentration level. Keep in mind, opening doors and windows to ventilate the space could change the concentration from a too rich environment to an explosive environment.
Any seemingly innocent action that would generate a spark or flame, such as flipping a light switch, adjusting the thermostat, or running hot water, could trigger a catastrophic explosion.
In this type of situation, you would be fully justified in bypassing normal communication channels to immediately notify the seller, the listing agent, and occupants for their safety.
Which BTW… (cell phone use) could also create the spark that causes an explosion!
Thank you! That is the best answer I’ve received. I appreciate your time
It seems like such an important topic. I was surprised that there wasn’t an InterNACHI article devoted to the subject. I was not satisfied with the responses that you received. While researching, I learned a few things that I didn’t previously know. Thanks for asking the question.
A friend of mine died a few years back as a result of injuries he sustained from an explosion in a house he was working in; likely due to him downplaying the severity of a gas leak.
https://www.wane.com/top-stories/man-inside-new-haven-home-when-it-exploded-remains-in-the-hospital-daughter-thanks-community/
