dnasser
(David Nasser)
October 23, 2010, 12:48am
#1
The valve’s were in the off position. Upstairs in the Attic is where the
heater was installed. Is this a gas cut-off? This would be a two story
townhouse in Southern calif.
If it is a gas cut-off, should I turn it on to check if the heater works? And
then turn it off again? Or should I say Standards of Practice do not let
me turned on valves in the off position…
Note…I tested for gas at the laundry gas valve…No gas.
http://i187.photobucket.com/albums/x296/dawlita/Socorro093-1-1.jpg
http://i187.photobucket.com/albums/x296/dawlita/Socorro093-1.jpg
jbraun
(James E. Braun, CMI)
October 23, 2010, 1:04am
#2
I would not. If it is an open pipe somewhere, you could blow up the house.
wwilson3
(Wayne Wilson, TN 439)
October 23, 2010, 1:21am
#3
If off leave it off, Ask why if anyone Knows, Note it. report it.
If your 100 percent where it goes just say it was in the off position. If your not sure then state unknown termination and advise a qualified contractor to investigate. Just my thought.
dnasser
(David Nasser)
October 23, 2010, 2:06am
#4
Thanks…I think I will leave it and just note. Based upon your feedback
I think its off for a reason.
dnasser
(David Nasser)
October 23, 2010, 2:07am
#5
wwilson3:
Thanks Wayne…Im not a 100 percent sure. Im going to refer to a contractor.
like you mentioned.
