Gas pipe starter for fireplace
My gas pipe log starter quit working, due to wear/heat. Having trouble finding a LP gas pipe starter bar. Home Depot has them for natural gas, but not LP.
I only use the gas starter for about 10 mins until I produce sufficent embers.
Thinking of buying a 12 inch black pipe and boring 1/8 inch holes in the pipe. Anyone have any input or suggestions? I know they have a different orifice but…?
Sounds like Harry Homeowners Association has found a new member…:wink:
Steve-0,
Thanks for the chuckle :mrgreen:
Without getting into much detail of the difference of NG and LP gas, I’m looking for a homemade fix. Would buy the NG starter bar but the orifices are too small. I suppose I could bore them out larger. But looking for a cheaper solution. Could always buy the LP starter pipe as well.
Looking for an ex-chimney sweep or HVAC guy or someone who’s successfully made a solution.
http://www.google.com/products?hl=en&safe=off&rlz=1C1CHMI_enUS341US341&num=100&q=gas+log+lighter+lp&um=1&ie=UTF-8&ei=Gvs_S5D6GoqKnQeT7cH0CA&sa=X&oi=product_result_group&ct=title&resnum=3&ved=0CCoQrQQwAg
That would work or you can pay $18.00 of so for a predrilled, threaded 1/2" stainless one from the fireplace company. :smiley:
I, myself, would consider changing out the shut off valve too if it is very old.
