pmccoy3
(Paul McCoy)
April 17, 2021, 5:18pm
Inspected home with multiple gas plumbing materials. I’m looking for advice on what my recommendation should be for my client?
It’s all done unprofessionally with improper supports, sagging, etc. There is copper tubing, flexible copper tubing, galvanized fittings, etc.
badair
(Barry Adair, EIFSTX#39)
April 17, 2021, 5:26pm
2
pmccoy3:
report what you believe to be a deficiency & let the cowchips fall however they do-do
jjonas
(Jeffrey Jonas)
3
Without knowing what your local utility allows for materials, my only concern would be the “sweated” copper connections. IMO, only threaded and/or compression (depending on material) fittings should be used for NG/LP connections.
