This outlet was in the garage…it has reset buttons but no receptacles.
I couldnt find out any outlet is controlled.
http://i187.photobucket.com/albums/x296/dawlita/Jackie040-1.jpg
No one can help you without going there, too.
Maybe a plan to add a jacuzzi tub?
I don’t know about that thing. Hopefully, you tested the outlets where they are required. If those didn’t trip, write it up.
I would not address that crazy GFCI breaker unless you know what it controls. I feel sure it controls some outlet somewhere, but it sounds like you couldn’t find it.
Leviton Switch-Rated GFCI, Back and Side Wired
(Model # 8590-RB)
http://www.twacomm.com/assets/images/popicon.gif Detail Box](http://www.twacomm.com/catalog/Leviton_switch-rated-gfci-back-and-side-wired.htm?sid=ABA985AB1AD1CE856BFC832680669C84) http://www.twacomm.com/assets/images/PDF.gif Product Brochure](http://assets.twacomm.com/assets/pdf/35546.pdf) (pdf)
Note: Picture may not represent the actual product. We are continuously working on improving our website and reserve the right to change specifications and availability without prior notice.
Switch-Rated GFCI, Back and Side Wired has a blank face, no indicator light, and the buttons are now black for the test button and red for the reset button. Switch-Rated GFCI Features:
Commonly used for spa tubs
thanks everybody
Agree. Just had one this week.
