Does anyone ever suggest this no electrician required GFCI solution for garages?
No, and probably won’t either, considering it’s a portable plug-in.
Completely agree.
I recommend GFCI protection and it’s up to them to do what they want. I would never recommend something like that item.
I’ve used similar products on job sites but wouldn’t suggest that as a proper solution to a homeowner…
Same here.
The argument against using this as a substitute for a proper GFCI receptacle or a breaker would be the same as that against using extension cords in lieu of a proper wiring: It’s a temporary, makeshift solution, and is not a replacement for permanent wiring or ground fault protection.
Agree
