Is there anyone you’d recommend for septic and well inspections in the Golden, Colorado area?
Thanks!
Jerry
Thanks!
Jerry
When I inspect a mountain property, Shirley Septic Service (Bailey, CO) 303-838-6033 usually pump the tanks so I can inspect inside the tank. I have not heard any negative comments about Shirley Septic Service .
Hope that helps.
Thanks
Jonathan
Shirley Septic (Conifer), Evergreen Septic (Evergreen)
GEOWater (Evergreen), Living Water (Conifer)
All good.
Thanks!
Remember, most of Golden is in Jeffco and Jeffco requires the seller to provide a tank/septic cert for the buyer,. Most if not all srevice companies pump the tank to provide the cert. You have no need to “look” into the tank.
