Any one have any ideas? My grind pump in the basement will not shut off. Float moves good.
Did you try unplugging it and powering it up again?
If that don’t work, it may be an air lock, maybe some debris under the float assembly, or a defective switch.
Took it out and cleaned it up. I think it was just a bit dirty. Working now. thanks David.
