Guidance seeking on exterior stone veneer defect
Hello! I am in the inspection contingency phase in th purchase of a home. Home is 3 years old and the purchase price is over $900K. Inspector has identified a stone veneer exterior defect that could have implications for the long term in terms of water seepage and impact to the structure of the home. Seeking guidance on the snippet of the report that pertains to the veneer defect. Have to make a decision if I have to move forward with the purchase or not and what the implications are. I understand that in cold weather like in Ohio at the moment, it is not possible to make any fixes before closing on the house in 30 days. Key Defects Identified:
  1. Amateur/improper installation of the stone veneer system
  2. Missing or improperly installed critical components:
    • Inadequate or missing flashing (beneath deck ledgers and at grade/concrete surfaces)
    • Improper vertical cracks at stone veneer corners
    • Lack of proper wall clearance from soil grade
  3. Non-compliance with ASTM C1780 standards
Report recommends recommends:
  1. Further invasive inspections to determine the full scope of issues
  2. Adherence to proper installation methods per building standards
  3. Verification of proper installation before considering the system acceptable.
The photos show visible gaps and improper terminations that are clear water entry points. This is not merely a cosmetic issue but a fundamental building envelope failure that will worsen over time.
Is the adhered stone veneer over CMU or framing?
Do you have pictures to share?
Is your concern whether the issues can be fixed or not?
What did the adhered stone veneer professional say when you contacted them?
Installation guide w/details:
https://www.masonryandhardscapes.org/?create-tek-pdf=1&post_id=520985&filename=MSV-MAN-001
I want to upload the detail. However the forum is not allowing me to upload an image.
I am concerned as to how big the issue is and if it requires a rip and replace of sorts. If it is a $50000 problem, i do not want to inherit. I do not want to purchase. However if the defect is not anything significant I might reconsider.
This seems serious.
What did the masonry contractor say that the inspector referred you to for evaluation and repair?
Send the full resolution pictures here [email protected] and I will try to upload them for all to view and possibly assist with opinions.
Thank You, uploading…
This is what you sent me.
It will not help anyone to assist you. Full resolution pictures are needed.
0000.pdf (81.7 KB)
^^^I’ll ask again.^^^
I have not gone to the masonry contractor yet. I thought I would get second inspector opinion first. Resent the image.
Still not helpful as it is low res and not enlargeable. We would have to see the issue.
The masonry contractor is the 1st opinion needed since he would be doing the work and can advise on the ability to make corrections and at what ballpark cost.
If you love the home, offer to pay the masonry contractor to consult with you in your time frame.
Good luck with this.
Thank You!
