# Heat pump breakers
**URL:** <https://forum.nachi.org/t/heat-pump-breakers/46497>\
**Category:** Electrical Inspections\
**Created:** [February 5, 2010, 6:22pm UTC](https://forum.nachi.org/t/heat-pump-breakers/46497 "2010-02-05T18:22:27Z")\
**Posts on this page:** 7\
**Page:** 1
<div class="post-metadata">
**Author:** ![mivie](https://sea2.discourse-cdn.com/internachi/user_avatar/forum.nachi.org/mivie/32/558_2.png) [@mivie](https://forum.nachi.org/u/mivie)\
**Post date:** [February 5, 2010, 6:22pm UTC](https://forum.nachi.org/t/heat-pump-breakers/46497/1 "2010-02-05T18:22:27Z")
</div>
A 3100 sq foot home. 200 amp box with 2 100 amp breakers for the heat pump. Is this normal?
**Author:** ![jbraun](https://sea2.discourse-cdn.com/internachi/user_avatar/forum.nachi.org/jbraun/32/536_2.png) [@jbraun](https://forum.nachi.org/u/jbraun)\
**Post date:** [February 5, 2010, 6:26pm UTC](https://forum.nachi.org/t/heat-pump-breakers/46497/2 "2010-02-05T18:26:29Z")
</div>
No, I would get your amp ratings off the unit or get the model number and pull up the specs. The biggest breakers I have seen on a residential HVAC unit was 60 amps and that is for electric heating elements
**Post date:** [February 5, 2010, 6:33pm UTC](https://forum.nachi.org/t/heat-pump-breakers/46497/3 "2010-02-05T18:33:00Z")
</div>
I told him the same thing. This is not from an inspection it is a friend that lives in another town. He called and said the breaker was hot. Wanted to know if it needed replaced.
**Post date:** [February 5, 2010, 6:37pm UTC](https://forum.nachi.org/t/heat-pump-breakers/46497/4 "2010-02-05T18:37:22Z")
</div>
If the breaker is hot than there is something drawing way too much current such as an electrical short.
**Post date:** [February 5, 2010, 6:39pm UTC](https://forum.nachi.org/t/heat-pump-breakers/46497/5 "2010-02-05T18:39:44Z")
</div>
He told me he has been running the heat strips for over a week.
**Post date:** [February 5, 2010, 6:48pm UTC](https://forum.nachi.org/t/heat-pump-breakers/46497/6 "2010-02-05T18:48:16Z")
</div>
I have never seen heat strips on a residential furnace pull that much current. A lose connection somewhere could cause excessive amp draw, or a maybe even a field grounding out in a motor. Just pull the amp load on each wire until you find it.
**Post date:** [February 5, 2010, 6:49pm UTC](https://forum.nachi.org/t/heat-pump-breakers/46497/7 "2010-02-05T18:49:22Z")
</div>
Thanks James. I will pass this information along.
