Heat Pump Testing
Originally Posted By: David Suelflow
65 degrees seems to be the cut off for testing either the heating or cooling mode of a heat pump. What do you guys do when it is 65 degrees during the inspection? Test heating or cooling or both?
Originally Posted By: dvalley
David,
65 degrees, on a heat pump....I inspect and test the operation and efficiency of both.![](upload://cr5E0bJe0JRvMEa68er70PzqFAL.gif)
David Valley
MAB Member
http://www.masscertified.com
