If you know what cubic/ft/minute or cubic/liters/min you want it is a simple math problem to convert David.
Lets see what Charley comes up with.
He did mention that he like to see his installs at 300-400 CFM’s…the meter will not convert for me?
Measure the register.
Say the register measures 1 square foot, and the velocity is 1 foot a minute.
That equals 1 cfm.
Eventually you will have a chart of the normal register sizes you come across with the proper conversions.
Damn, I hate math.
Alnor is the Hvac industry standard test equipment used that brand it seems like a hundred years ago. We had vent hoods with sash type glass doors that were connected to pneumatic/electronic controlled Bladder VAV’s that increased or decreased CFM according to the position of the door a OSHA requirement for laboratory use in R&D. These doors were required Preventive maint checks
David let me give you an example of why you don’t want to go there. To many variables you will not be able to take an anemometer around to the registers and simply say this is correct or this is wrong. I am sticking my neck out further than I like to do as I normally do not quote Stats and or formulas on this board to many guys take it as chiseled in stone. You Stated you do not like math well if you decide on this path you better get to like it.
If The heated air is furnishing all of the heat for a room, 3 things must be known to be able calculate the air volume.
Engineers recommend that a grille Temp be at least 125 degrees and that duct temps be near 140 degrees. The lowest temp needed to obtain these result depend on the duct lengths. Knowing that the specific heat of air is .24 BTU/LB the weight of air needed is found by the specific heat equation
Room heat load = .24 X wt, of air X the temp difference.
To obtain the volume you must first find the volume of one pound of air at the duct temp. This value is obtained from a psychrometric chart.
One pound of air = 17.1 Cu.Ft.
David I have a book with all of these formulas but I think I have made my point don’t go there, not a good Idea for the HI, I do not use a meter to check air volume and do not state so in my reports. My statement is generally System appears to be performing or system appears not to be performing. Let the Hvac’s make the determination.
Obviously not using all your brain/skills at that point in your life!
:twisted: :twisted:
I have been on a Brain Rationing program from an early age, as you may have noticed on other threads, some people have run out.
:twisted:
Charley,
When I seen your numbers, it changed my mind.
Thanks.
Good call … it gets sticky … ![]()
That is pretty much why my anemometer is collecting dust somewhere. ![]()
http://www.ambientweather.com/newke30powim.html
This one does the most for the $. And is real small. And it’s certified.
As far as doing math, for residential stuff you can get a square to round boot in the three sizes commonly used and all you have to worry about is the outlet size of the boot. All that averaging creates too big or an error factor.
Are you using “net free” areas of the registers as given by manufacturers in your calculations?
This might sound to simple but, Is the bedroom door open or closed. If the door is closed and the gap at the bottom of the door is small the pressure in the room may get higher or equal to the air being pushed into the room alla no warm air gets into the room. My teenage daughter use to complain about this problem and thought I was nuts untill she started sleeping with the door open.
I use the TAB protocol from SMACNA.
And neither do I do any of this in a home inspection. I do measure ft/sec supply air (if I can’t feel good flow) and returns if they are loud. Air flow below 300 ft/sec generally does not have the throw or capacity to heat/cool the room. We use a lot of heat pumps here so velocity expectations can be higher.
I just SWAG it for the most part. I can tell when things are not right.
I also use my IR. Air throw patterns. Air stratification ect…
